Chocobos can go rot in hell. (Another anecdote.)
- CM August
- Omni Hunter
- Omnizzy
I can't believe that some of you never heard of TelStar and some of the other optional bosses. Getting some of the characters again before facing Kefka is optional with some coming with a boss like Shadow or Relm. The Hidoon is also optional if I remember correctly and you can face it as many times as you like.
- Baba O'Reily
- ABBA BANNED
- Location: http://zenixstudios.com/files/ 554SpaceIsThePlace.Mp3
- Omni Hunter
- Omnizzy
- Psxphile
Don't you get 10 for refining one of the GF cards? I believe it was Diablo's or one of the Minotaur brothers, but I'm certain it's one you get automatically and not won from a player or found.Actually, on that note, who's been able to refine a "Dark Matter" in 8. I can't seem to do so.
I'm surprised that people missed out on fighting Telstar. He <b>is</b> pretty tough considering you'd only have Sabin and Shadow (if you're lucky) at that point. But with Shadow's shurikens you can make quick work of it. Gives a Green Beret when it dies, too (in fact, the bastard keeps coming back on the Veldt.... Green Beret's all round). On that note, was anyone aware of the rear tent you can only access by jumping over the wall? Nothing too impressive in the chest inside, but I must of wondered how to get in there over a dozen times and completely ignored stepping on the ground tile that would send you jumping over to it.
Anyone find the second Memento Ring?
- tornadot
There are two Memento Rings? I never knew that...hold up Telstar gives you a Green beret? Now I think I remember facing that boss in the camp, and I think I died more often than I liked...
As for tough as a boss, annyone remember the Dinosaur Forest and the Brachosaur and the Tyranosaur? The former completely wiped me out with Ultima...o_O
- Neo Yi
VGJustice
Yeah, the hardest thing to find was the limit breaks. Correct me if I'm wrong, but I do believe that FFVI was the first one in the series to have limit breaks. Not like it matters, they were almost impossible to pull off. I've only ever seen one: Sabin's Tiger Break. Poor little random encounter weenies that got hit with that. Made me feel sorry for 'em.
- tornadot
- Omni Hunter
- Omnizzy
- Ancient
It's a bad habit of mine to assume that all the extra side-quests at the end of VI are the main game. I mean, what idiot fights Kefka after they get the airship anyway?
And some of those bosses are not overly easy, true. But they aren't the same as the Weapons, which serve only one purpose. To be hard! FFVI is probably the easiest FF I've played taking all the side-quests into account.
And Baba, using a quote to say that doesn't work. I'm not retarded enough to speak about myself in the 3rd person (although I should be considering the forum I'm on).
<img src="http://www.dontfeedthewriter.com/11t/cow.jpg">
- tornadot
- smiths32
VGJustice
