Help please!
- smiths32
Help please!
Right, today I just got a MK1 Mega CD in the mail today (supposedly) complete with all leads. However the bastard didn't come with instructions so I'm left rather clueless on what to do, I took off that thingy on the right of my Mega Drive so that they plug in, problem is I'm stuck now. So, I was wondering if you guys could be really nice and help me out here since some of you'ze seem to have some experience here, thanks very much.
BTW please use simple words to describe the parts, okay?
plasticwingsband
- ASSMAN
- smiths32
- big_smile
Re: Help please!
Make sure you remove the plastic red cover (that is inside the Mega Drive) that says "[Electric Shock Symbol] DO NOT REMOVE".smiths32 wrote:Right, today I just got a MK1 Mega CD in the mail today (supposedly) complete with all leads. However the bastard didn't come with instructions so I'm left rather clueless on what to do, I took off that thingy on the right of my Mega Drive so that they plug in, problem is I'm stuck now. So, I was wondering if you guys could be really nice and help me out here since some of you'ze seem to have some experience here, thanks very much.
I didn't know that was supposed to be removed (as it clearly warns against doing so) and so wasted hours trying to figure out what to do.
^_^
Edit: you posted at the same time as me ^_^
Both power packs must be used (one for the MD and the other for the MCD).Yup, did that, but I don't know what to do now, do I use both power packs?
What switch?! Are you connecting to a MK1 MD (as my MK1 MCD/MD has no switch)?And where does the Mega Drive to Mega CD switch plug into on my Mega Drive?
Thanks.
^_^
- smiths32
- smiths32
- Spazz
See if <a href="http://db.gamefaqs.com/console/segacd/f ... t">this</a> helps at all. It's mainly history and technical stuff, but it may help you out a bit.The Genesis is connected to the Sega CD unit via the interface slot, and
a/v hookups are made through the Sega CD unit instead of the Genesis.
The advantage of this is that games can take advantage of the sound
provided directly by the compact disc in addition to sound effects from
the Genesis unit itself.
- smiths32
Thanks Spazz, but I've already checked that out; I've even went as low as to look on the Game FAQs boards. It's funny that everyone says that the 32x is so hard to setup, but is it much harder than this? I mean I've seen numerous setup guides for it, but not this. I swear I'm going to need a degree in IT to set this hunk of junk up. Come on, surely some of you guys owned one.
- Spazz
- smiths32
- Spazz
It looks like it should be right on the side:
<img src="http://www.livaudaisnet.com/Cory/megacirc.jpg">
I'm pretty sure the RF cable should plug into the back of the Mega CD and not the Megadrive.
- WhoopA
- smiths32
- Spazz
Wait, I don't see a place where it would plug in <i>from</i> the MD:
<img src="http://www.livaudaisnet.com/Cory/backcd.jpg">
Maybe all you have to do is plug the RF unit into the MCD, although I think this is from model 2.
If it's different from the pic above, you should have two cables. One short cable and the main RF cable. On the back of the Megadrive, plug the short cable into where the RF cable usually goes. Then, plug the other end of it into the back of the Mega CD so it gets the signal from the MD. After that, all you have to do is plug the RF cable into the MCD, and you should be set. (This is the same way to set up the 32X)
What is this world coming too when people can't setup old VG hardware, eh? >_^
- WhoopA
- big_smile
Just in case it is still not working:
The only wire an MCD needs is a power adapter. All other wires are surplus. (The MD uses its existing power adapter and AV cable).
Sega Europe re-designed the power adapter when releasing the MD2 and this new adapter will not work with MCD1. The MCD1 adapter should look identical to the MD1 adapter (you can even test it on your MD1 to see if it works). The newer adapter has pieces of yellow plastic on it.
If you have the newer MCD2, MD2 or 32X style adapter, the MCD will not work.
^_^
^_^
- Spazz
Finally! It was hidden within the bowels of the internet, but I found it.
<a href="http://sf.victoly.com/SCD/">This</a> should tell you everything. It's for the US version, but it shouldn't be that much different aside from what big_smile said. Just skip the 32X parts.
- smiths32
