3D models and textures - help plz?
I downloaded K-3D (Version 0.8.0.1) last night. I figured out how to import .DAE model files just fine, but can't figure out how to apply textures.
In particular I'm trying to view Mecha Sonic from Sonic Adventure DX. The textures are all .png format. Basically I'm an idiot, please help. Thanks.
Re: 3D models and textures - help plz?
Without wanting to sound condescending, you might have more luck on an actual 3D forum than here.
I was thinking the forum at the site where you got the files in the first place would be your best bet. I don't know anything about the program you're using.. does it have like, Materials, or something similar? (Textures are often imported onto materials!)
Ah well, thought it was worth a shot. Thanks anyway guys. Will look for a 3D modelling forum that will tolerate newbie questions.
