- WW
- WW
- Senbei
That is nicely done--one of the best Feux-Uekawa's I've seen! That means I'm gonna niggle slightly--his left eyebrow (our right) seems a little overlarge for the style, but the thing that actually attracted me to it is the highlight, it seems like, just due to the size of it, it ought to be just a bit brighter, maybe. Also, what's the black line on his buckle indicate? It's the wrong angle for the hole in the ring to be seen, and it's cutting across the shading.. what's it doing there?
He also totally looks like he's gonna eat that bird.
- Owen Axel
It's not theft if you ask before and give credit after. Unless he says no, of course, which would be fair since you had the audacity, yes the audacity, to copy his work like the lower-class filth that you are, you pheasant!SegaSonic wrote:Its so awesome I made it into an avatar, you dont mind right? ....
- WW
- EmeraldGuardian
Well, I did take the colors and highlights from the usual official art, so maybe it's just my style that makes it look weird? The line on the buckle is supposed to indicate an angle in it's rectangluar shape. Ehh I don't know if it'd be seen from that angle but I tried.G.Silver wrote:That is nicely done--one of the best Feux-Uekawa's I've seen! That means I'm gonna niggle slightly--his left eyebrow (our right) seems a little overlarge for the style, but the thing that actually attracted me to it is the highlight, it seems like, just due to the size of it, it ought to be just a bit brighter, maybe. Also, what's the black line on his buckle indicate? It's the wrong angle for the hole in the ring to be seen, and it's cutting across the shading.. what's it doing there?
WW, I love all your stuff, and that popeye crossover is brilliant! What medium pencils do you use?
- WW
There is a slight stylistic difference, but I think it works, you had me fooled long enough to think you were just posting official artwork in here for some reason. The eyebrows are really quite cool, I like 'em. I think with the line, if I understand what you're saying, should probably match the outline of the buckle more, so it's not breaking into the highlight. If I understand what you mean. But it's awesome in any case. :)Well, I did take the colors and highlights from the usual official art, so maybe it's just my style that makes it look weird? The line on the buckle is supposed to indicate an angle in it's rectangluar shape. Ehh I don't know if it'd be seen from that angle but I tried.
- jenkins
For "pheasants" read "peasants" throughout.Owen Axel wrote:It's not theft if you ask before and give credit after. Unless he says no, of course, which would be fair since you had the audacity, yes the audacity, to copy his work like the lower-class filth that you are, you pheasant!SegaSonic wrote:Its so awesome I made it into an avatar, you dont mind right? .... :shock:
1066 lol
