Isuka wrote:... I'll suppose you get to such numbers by means of Chao breeding, because if it was for mastering every single stage with an A... I'd fear this game.
Also, are these Sonic Shuffle button-mashing mini-games anything like the torture scene of MGS? If so it's not that impossible.
I've been mulling around the idea of DC emulation just to play the Green Hill Zone remake. Has anyone here done it? Is it worth it?
Sonic Advance page wrote:Trick Point (トリックポイント) -- Press button B to perform an aerial trick just as you pass through the flashing panel. If you're timing's on, you'll be awarded a hefty Ring bonus.
Sonic Advance page wrote:Any previously accessed Zone or Act can be revisted at will via the main menu.
Ritz wrote:Hammering, kinda. It's hard to explain, but I sort of know how to make my hand vibrate. It's a gift, really. I can't pull it off through any means other than vibration.
I own SA2:B--it's been a while since I've played the GHZ redux stage, but I remember it relatively fondly. My favorite parts were the stage's opening (which starts off looking like the 2D game but then suddenly explodes into 3D) and the remixed theme.Locit wrote:I've been mulling around the idea of DC emulation just to play the Green Hill Zone remake. Has anyone here done it? Is it worth it?
Neo Chaotikal wrote:Also, this:Sonic Advance page wrote:Trick Point (トリックポイント) -- Press button B to perform an aerial trick just as you pass through the flashing panel. If you're timing's on, you'll be awarded a hefty Ring bonus.
IF YOU'RE TIMING'S ON
Sonic'll home around and hit destroy any enemy in the vicinity
If you die, you start all the way back at stage 1. Good freaking luck.
Since you're apparently updating the Sonic Heroes page, the PS2 version atleast(XBox too, probably) can be switched to Japanese voice from the options menu. It's just to the left of the text language. In bottom section it says you have to change the console's settings, which you don't.
Sonic Advance 2 page wrote:After flying off a ramp, press R and any direction on the D-pad to perform an aerial Trick Action.
Isuka wrote:Sonic Advance 2 wrote:After flying off a ramp, press R and any direction on the D-pad to perform an aerial Trick Action.
If I recall, if you manage to press the Jump button while walking on the ramp you'll instantly get a big burst of speed, getting into Boost mode.
And about the acceleration thing, it looks like the more rings you manage to amass at one time, the faster you get to maximum speed before breaking into Boost mode. This is particularly noticeable when you get hit after collecting some 50 or more rings (without a barrier), you'll find the character much "heavier" than it was just a second before the impact.
Green Gibbon! wrote:Since you're apparently updating the Sonic Heroes page, the PS2 version atleast(XBox too, probably) can be switched to Japanese voice from the options menu. It's just to the left of the text language. In bottom section it says you have to change the console's settings, which you don't.
I keep hearing conflicting reports about this, but I don't have either version to test it myself. Can anyone else confirm?
Users browsing this forum: No registered users and 1 guest
