<a href="http://www.1up.com/do/newsStory?cId=3153685">Don't panic</a>!
The paradigm shift is surprising, and a tiny neanderthal isn't nearly as delightfully unnerving as a man-faced fish, but it's ultimately nothing more than an aesthetic change. As long as the interaction is up to par, I'll be quite satisfied.
Seaman 2
Long story short:
The myth of Seaman is that an Egyptian wizard turned two starcrossed-lovers into a birdwoman and a seaman, respectively.
The science of Seaman says that they're parasitic creatures that take on whatever form a seaman larvae is consumed by, and then bursts out of. So if it's eaten by a fish, they become fish people. But if it's eaten by a crane or something you get birdy people.
Sadly the bird seamen were never introduced in actual gameplay, just talked about.
There's no huge time commitment required for Seaman - you have to pop it in once or twice a day to adjust the temperature, but your sittings don't have to be any longer than 2 or 3 minutes. It's the sort of thing you can do before leaving for work in the morning. It's actually kind of therapeutic, or it would be if it weren't so bloodcurdling.
