Bikini Girl and balls! So fun!
Has every one seen this?
http://www.izpitera.ru/lj/tetka.swf
Yeah. Surprisingly amusing.
That's... random.
I can't decide if this is a gateway for necrophelia, S&M, or just a really kickass waterslide.
Also, the shadow makes her legs look all hairy.
I modelled for that. The lady and the bubbles.
WhoopA
Post by WhoopA »
Ragdoll physics in Flash? Who'da thunk it.
Green Gibbon! wrote:I modelled for that. The lady and the bubbles.
I knew you didn't look like your avatar! So you look like Ellen DeGeneres then?
Am I childish for making her hump the bubbles?
Omni Hunter
Omnizzy
Post by Omni Hunter »
I'm glad I wasn't the only one to do it
j-man wrote:Am I childish for making her hump the bubbles?
Yes. But you're not alone.
Of that I am glad.
I actually sat there messing about with that thing for like 20 minutes, all the while giggling insanely at every inhuman convulsion and spasmodic movement, much as an evil deity might cackle while dabbling with the fates of men.
Protodude
Post by Protodude »
I don't know how, but I made some of the bubbles go away one time.
You threw her upwards. That's against the rules. Boo, man. Boo.
Protodude
Post by Protodude »
Hey, I just wanted to throw her around a little bit. Jeez.
Dunjohn
Post by Dunjohn »
If you kinda grab her arms, then slowly lower or below the edge of the screen, the upper bubbles will vanish as the lower ones load in.
See, I discovered a cheat code already. Now we can reach previously impassable areas.
If you stretch the window, make it like a stripe, you'll be able to throw her upwards easier. And you'll be able to throw her downwards easier too, and faster. If you do that, she will go through most of the balls. That's the no clipping mode. IDCLIP baby.
Kishi
Post by Kishi »
If you beat it on hard mode you can play as Popcorn's Mom. She's too wide to slip through some of the passages, but she can crash through the bubbles if you build up enough momentum.
Baba O'Reily
ABBA BANNED
Location: http://zenixstudios.com/files/ 554SpaceIsThePlace.Mp3
Post by Baba O'Reily »
I just pull her through the gaps. I also like to flip her around and see the occasional 360 degree spin.
